tommy2tone
I seen were tutorials talk about drilling the casing and inserting the transmission. Was wondering about the top part. If you turn the blank to the diameter of the casing then the top will be "to fat" for a slimline clip. And vise versa the bottom will be to small (using 7mm bushings) to cover the bottom of the bullet all the way. Do you use just one of each? A bullet bushing at the bottom and taper it to a slimline at the top? Also I guess you have to flip the bullet bushing around (on the mandrel) as the little part will not fit in a slimline tube.
