Justturnin
I hope this is the place to ask this.
I recently picked up some 1/4" Expanded Core PVC sheets on CL for super cheap. These are 24"x48" sheets and I want to build some trays w/ 1" walls to go in the cabinets I just installed in my shop. I want to use these trays to hold chemicals and things that could leak w/out me being aware of it so I want them to be leak proof to contain the leak. I was told that there is a urethane glue I can use but am not sure which one. Does anyone have experience working w/ PVC sheeting and if so how did you glue it up?
Any help would be appreciated.
EDIT:
I would also like to add, I want the glue to be somewhat flexible because the PVC will likely flex and bend when moving it so I want to avoid brittle/rigid glues.
EDIT:
