Public service reminder: clean your bushings
Dan Masshardt
Mechanicsburg, PA
...every time.
A set of TBC bushings that looked clean.
The shoulder usually has a little dirt on it. The 60 degree taper always seems to have crap in it.
This is wiped with acetone.
Perhaps I am going out on a limb here but I discovered if you WAX the inserts then it's simply wipe away the junk when your done, no buildup.
Seems also there is more buildup on the outside that contacts the chisel/sandpaper than anything and the index point on the centers gets the most abuse it seems (those 2 areas)
Have been known to ultrasonic cleaner w/ simple green.
Two Words:
Krud Kutter!
If you could drive a 1909 Hudson into an ultra sonic cleaner filled with Krud Kutter, not only would it look like new, the Hudson Motor Company would likely still be in business!
One night after a few too many Coors Lights, I spilled a gallon of krud Kutter all over myself . NOT ONLY was my wife "hitting on me", but the neighborhood women brought me bacon and junk
That stuff is better than Hai Karate:biggrin:
