Couldn't find this on wikipedia
The throat is the distance from the blade to the vertical frame section of the body of the saw. This distance determines the width of cut that can be completed on the band saw. The throat on a free-standing cabinet band saw typically exceeds the 12 to 14-inch throat of smaller, bench-top models. When you see the term "18-inch Band Saw" advertised, realize that it is the throat measurement to which the manufacturer is referring.
Throat and wheel diam does not always equal.
What... is... that...???
And where can I get one?
that is what we call a band saw. This one cuts 31" and uses 15" wheels.
you can build one.
Plans for band saw
Building a Bandsaw… From scratch.
could also buy one to.
Photo Index - Du-er Tools - Du-er 4-Wheel Band Saw | VintageMachinery.org
Wegener Welding |*Plastic Pipe Band Saws |*RS 1600 63"
West Point Blog: December 2010
For a bandsaw to cut longer objects you will need some type of deep throat option, hence the 4 wheels.
Some others have more than 4 wheels by design.
