Harbor freight dust collector?
Haynie
Page Arizona
I am in need of a dust collector. Wood working and metal grinding are messy and I am being over whelmed. I have machines from HF as well as several bullet proof grinders from them and have been more than satisfied. I was looking at the dust collector to help with the dust issue. The reviews are pretty favorable with a couple well founded complaints. I plan to build a Thein (sp) or vortex separator to help it out. I was hoping to get comments from actual owners about the machine.
So, how does it work?
Own it, Use it, Love it. It does everything I needed a dust collection system to do, I run it for all my machines with 4 different blast gates and would recommend it.
And I hate 99% of everything HF has to offer. This is one of the good things I have found
I've had it but only for about a month and I'm happy with it so far. If they will let you combine the coupon with the sale price it can be as low as $150 before tax. On my mini-lathe with a tight dust hood it is pulling 90% of the dust and shavings I make on the lathe.
Shorter warranty than many other brands. I hear adding a Wynn air filter is a nice way to upgrade it.
The manual that came with mine was outdated as it was calling for nut and bolt installation on a lot of points where the sheet metal of the base had been changed to allow for bolt installation without nuts. If you get it and feel like you've been shorted on hardware check to see if this is the case.
Thanks folks. I was told by a local here how bad the wood dust was in my shop. I had been in there planing some boards and did not think about it since I was planing and jointing, not sanding. He said it was like walking into a cloud. The next morning, after enough time for settling, I went in, saw the dust, walked out, and drove to the hardware store for new face mask filters. Time for a dust collector.
Haynie; Here is my slant and experience with dust collection systems. I have 5 different systems in my shop, each one has it's own purpose. 1 is a two bag, 1 micron, 1 1/2 horse motor PSI system with a vortex separator and both 4 and 6 inch y outlets. I use this for the heavy use machines like the planer, shaper, or router table when doing big jobs. It's on wheels, but not easy to move around. 2 Is a setup I use for machines that may have a little larger cut offs or chips. Same dust blower, but set up with a separator made out of an old Caftsman shop vac that has a 30 gallon container. This will drop all the heavys into it without filling the dust collector bags. You can buy the lid and use a trash can for the bottom or make your own. Be sure to put a divertor on the intake to give it the vortex. A 90 degree elbow will work just fine. 3 Is a clear plastic tube system that runs to machines that are stationary or seldom moved or used. My Leigh Dovetail jig that is set on it's own table, grinders, and medium sized machines use this system. 4 Is a Wet/Dry Shop Vac on wheels that I can move around with little effort and connect to my lathes, disk grinder, and belt sanders. 5 Are small Stanley shop vacs that hook up to small machines and sit under them. I hook these up to table top machines and my mini lathe. I know this sounds like overkill, by remember I have been a tool collector for over 50 years and I like to be able to just go to the tool I need, turn it on, and use it witout any moving or attaching equipment. Most important thing to remember is bigger is better. Figure out how many cubic feet of shop space you have, and get a system that will replace that amount of air every 5 to 10 minutes. Think about what your future needs might be and buy or make a system that will handle that need the first time. I rarely use either of my large systems any more, or even the tube system anymore. I use the large Shop Vac and the little Stanley vacs ( $11 each ) for most of my work. One problem with a large system, is that you have to bring the dust to it. So the shop vac can be easily wheeled any place you want to go with it. I do a lot of work outside if it is nice, and dragging the 50 foot 6 inch hose from my large systems gets old fast. I have many of HF's mini tools and have been very satisifed with them. They stand behind everything they sell, and if you have a problem they take care of it. Hope this helps! Jim S
Bought almost ten years ago back when came with 30 micron bags, so bought a Wynn canister before using. Would buy a Wynn canister if buying one today.
Dust Collector - Great Deals on Dust Collectors at Harbor Freight
Had to replace on off switch, shipping cost more than the part, but at least they had one in
stock.
35A Series Cartridge Kit
I had to drive two hours each way to nearest HF store and even with Wynn canister best deal for the money back then. Have a store in my town now, so if this one finally quits running buy a new one and put my canister on that one.
My only complaint is noise!
Yes, would rather have a Delta 50-850, with canister but cannot buy local.
You state metal grinding as one of the uses for the dust collector. If this is a process that causes sparks, DO NOT hook it up to a dust collector. You will be setting yourself up for a fire or explosion, possibly both. Be safe.
Jake
