Blanks from Greenwood UK Cherry - Help Please
Pen turn
Doncaster UK
As I am relatively new to penturning, I thought I would ask my question here as everywhere I have researched seems to provide contradictory advice.
My neighbour has today cut down a Cherry Tree (Flowers with white Blossom) UK Tree. I thought it was a waste and I should take advantage of preparing the wood for future pen blanks. I have purchased some "End Sealer" today in preparation.
My question is - Whats the best way to prepare the trunk for future use.
A - Cut into pen blank sizes - seal end grain - dry
B Cut into Manageable logs - seal end grain (leave bark on or off)???
Your advice would be very much appreciated.
My second question - I believe there are two types of Cherry Tree, Fruit and Flower. I think this is the Flower variety is this still suitable for pen blanks.
Thank you to anyone that can provide me with some advise.
Cheers Simon :laugh:
bellringer 75
Surrey england
I have a load of cherry and the best thing to do is to cut it to size then seal it with wax i have done a load with this and it worked for me
D.Oliver
Faith SD
First off, Welcome to the group Simon. Now on to your questions.
This depends on what you plan to turn. If all you turn is pens I would go ahead and take them down to larger than pen sizes ( I like 1"x 1"). By doing this they will dry faster than if you leave them in log sizes. I like 1" x 1" because as the blanks dry they will shrink a little. They also may warp and twist a little. By leaving them a little bigger, I ensure that I will still useable blank after shrinkage and any warping or twisting. If however you plan to turn bowls or platters I would leave them in log form and just seal the ends. It won't dry as fast in the larger size though.
Both will make good pen blanks.
Pen turn
Doncaster UK
Thank you "Bellringer 75" and "D.Oliver" thank you for your comments.
D.Oliver I think I will do as you say, cut them at 1 inch pen blanks and then leave a few logs for possible bowl Turing in the future. I have never done a bowl as yet, but something I do intend to do, so they will come in handy for practicing.
Thanks again for the advice
Sandy H.
Charlotte, NC
For clarification, would you coat the blanks all over with sealer (or wax or other) after roughing to 1" x 1" x 6" pieces, or just the ends? I also would like to try using some of the lumber we cut, even if it isn't exotic.
Sandy.
D.Oliver
Faith SD
I don't know how others do it, but i just dip the last 3/4" of each end into the sealer.
SteveG
Eugene, Oregon 97404
Blanks and other pieces that are green that are straight grain, get sealer on the ends. If it is highly figured or burl, where grain runs in many different directions, it is common practice to seal the entire piece. This results in a MUCH slower drying cycle.
