Painting Blanks & Tubes
Jamesomac
Nova Scotia
Does anyone have any opinions on what type of paint to use on tubes and blanks. I would prefer to use water based hobby paint applied with a cotton swab, but found that the two-part epoxy dissolved the paint. Maybe I didn't wait long enough for it to dry. I tried spraying from a can, and that created a mess. I use the epoxy instead of CA glue because I don't work fast enough to use CA.
r1237h
Port Moody, British Columbia
Have you tried thick CA?
webberville, mi
It's not your original Q, but I've used epoxy (varying set times and I prefer the 5 minute), I've used CA (thin, medium and the "special" formulation sold by PSI), I've used expanding polyurethane glues (aka Gorilla glue) and I prefer the 5 minute, 2 part epoxy. I find the epoxy a little too short on set time, but the end result has (IMHO) the longest lasting structure. It retains a wee bit of flexibility and does NOT get brittle over time (the polyurethane glue does - again IMHO).
To your original Q - when I paint, I usually use a "hobby store" set of acrylics. I've had excellent results. I paint both the blank AND the tube (belt & suspenders mindset). I've found that without a fan the blank doesn't get much air circulation and it requires a lot more dry time than the tube. When I need white or black, I spray. I have a tapered dowel that is my tube holder. When I do the blank I put on some nitrile gloves and hold it.
One other thing - when you paint both the tube AND the blank, you occasionally tend to make the fit too tight. So I test the fit before I paint and, if necessary, I "ream" the blank a bit with 220 wrapped around a dowel or whatever.
Hope this answers your Q
Monty
Group Buy Coordinator
Pearland, Texas, USA.
No, I never tried the thick. How long is the working time before everything freezes up?
Depends. I was using the stick-fast glue, and had a good while to properly spin and seat tubes. Now, I have the E-Z Bond glue, and if I don't get the tube positioned within a few seconds, I'm screwed.
With EZ Bond thick, you should have 15-20 seconds to get the tube set.
Nokesville, Virginia 20182
I started using acrylics and had the same problem on occasion. Someone on a forum here suggested Testors model paint and I haven't had any problems since switching. Not quite the variety of colors available but I'm satisfied so far.
panamag8or
Hogtown, Florida (Gainesville)
It was more like 8-10 seconds. I was dealing with historic wood and expensive kits, so I was :eek:, almost having a disaster. I barely had time to insert the tube before it was sticking. Maybe I should put it in the fridge, like they say.
BSea
Little Rock, Arkansas
I use the acrylic paints from Michaels, and glue the tube in with 5 minute epoxy. If your paint is being dissolved by the epoxy, I don't think you've let it cure long enough. It needs to be more than dry to the touch. I wait at least overnight, and usually have a fan blowing through the tubes during that time. I know others that put their painted tubes in a toaster oven to speed drying.
You can also add a small amount (a very small amount) of paint to the epoxy to help tinting. If you add too much the glue won't harden. Just a small amount on a toothpick will do. No more than a drop.
Carl Fisher
Cape Coral, FL
This is exactly the method I use as well. Acrylic paint tubes are dirt cheap at Michaels or Hobby Lobby (like $0.99 each) an besides reverse painting the blank, a very small drop of paint in the epoxy mixed up will do nicely to color the epoxy. Between these two you should never have a problem unless you didn't wait long enough for the paint to dry.
Jamesomac
Nova Scotia
I bought some 2 OZ bottles of acrylic from Walmart (I could not find Testors) and tried that after reading all the comments. This time I allowed for a longer drying time, and even dried the inside of the blank with my wife's hairdryer. I then used the 2-part epoxy and it worked fine. The paint did not dissolve at all. Next time I will try adding a drop to the glue mixture.
One thing I noticed is that, because the paints tends to lay pretty thick, it may be necessary to ream out the blank slightly with a dowel and sandpaper first.
tim self
Atoka, Oklahoma
For sanding the inside, I went to the extreme. A 2x3 piece of Abranet glued to a 7mm tube (only along one edge). An old 1/4" drill bit inside to prevent collapse and then "drill" the blank wet sanding. Especially helpful if using a clear or translucent blank for removing drill marks. Then paint. It "reams" the blank and leaves a smoother surface.
