CoastalRyan
Alright these are my first two pens so I'm thinking there's something wrong execution wise. Wrong process? Yes I have searched endlessly which is how I learned about WTF, MM and PlastX.
So let me be thorough here so you know exactly what I've done.
These two pens don't look too far off from each other. Really I'm looking for more of a glass finish. The first one is basically for comparison purposes.
So first up I sanded this pen to 600. Rubbed some Carnuba wax right on the blank while it was spinning and heated it up with a paper towel. Then buffed with Tripoli followed by White Diamond at 2,500 RPM's on my lathe.
Second one below I sanded to 600. Applied 7 coats of WTF. The sixth coat was the first coat that looked glossy. So I followed it up with one more for good measure. Wet sanded using MM from 1,500 -12,000. Buffed with Tripoli followed by White Diamond. Then applied Plastx and hand buffed with a microfiber cloth.
I expected better. So method, process or product? Where am I going wrong. Should I have applied another 4-5 coats of WTF? It really didn't create a hard finish like I expected. Maybe the coats were too light?
Should I have applied the PlastX on the lathe and heated it up or buffed it out on the wheel? It says to wipe it off before it dries and to be honest it made it less glossy not more.
Basically I need to lock down a good pattern that would achieve better results. I think they turned out nice but for the times where I'm looking for a glass like finish what can I do.
