Cutting 1/8" acrylic sheet
Monty
Group Buy Coordinator
Pearland, Texas, USA.
I need to cut a hole in a sheet of 1/8" acrylic approximately 2-7/8" X 7-1/2" in this shape -
I tried using a scroll saw but after it cut, it melted back together and I was unable to get the center out with out the acrylic breaking.
Any suggestions for cutting would be greatly appreciated.
Two methods I have used.
First is my rotozip with a double cut bit, then sand the edge.
The other method and the best in my opinion, my scroll saw. Put a layer of packing tape on both sides of the acrylic and cut as usual. The tape helps lubricate the blade and the kerf doesn't melt back together.
I hope that is helpful for you.:wink:
keep the area wet (water will work) and insert tiny wood shims behind the cut as you make it.
A scrollsaw with the widest blade possible is better than a sabre saw, cause you can see the back of the blade and insert the shims faster--the water keeps it from melting together.
Edit in: I like Kelly's way better---try it first!!
We typed simultaneously
Kelly's way is the better way. When I was in AM school years ago this is what we were taught and I know it works, also there is something in the clear packing tape that helps lubricate the plastic when you are cutting it.
I would cut out a template from a piece of plywood or MDF, then use double stick tape to stick it to the acrylic and use a template bit or pattern bit in my router to get a perfect cut. No melting to worry with and a much cleaner cut.
That was one of my thoughts also, but I figured it would melt to the bit and make a big mess.
It won't melt. I do it almost every day on the chambers I build. No telling how many thousands of feet of routing I have done in acrylic of all different thicknesses.
Thanks for the suggestion, Curtis. It worked great. Made a template out of MDF, drilled the ends out with a hole saw and connected them with a saber saw, refines the edges to fit with a wood rasp. Once the hole in the MDF fit, I used double sided sticky tape to hold the acrylic to it and cut it with a pattern bit in my router.
Thanks again to everyone fro their suggestions.
What Kelly said. Put packing tape over and under the area you are cutting. It's fast and easy. Never once had the acrylic melt back together.
