JD Combs Sr
I have some BLM burl pieces, bowl blank cut-offs courtesy of a friend on another forum, I have used most of the larger pieces but still have some 1-2 inches long. Here are a couple I salvage by casting two in red Alumilite. I painted the inside of the drilled blank black, kinda wish I had used white but will try white next time.
Pen is a CSUSA chrome long clicker. Finish is 10 coats of med CA polished to 12000mm.
In areas where the resin goes all the way to the tube it appears black, white would have showed the red better.
C&C appreciated.
C&C appreciated.
