Axminster w/ Custom Twist
See more from KDM
KDM
Redditch, England
Really enjoying these Axminster kits. Here's a custom mica swirl my wife requested.
I cut the blank such that I had a pattern matched piece to make a new transmission knob with.
Closeup shows the flaw. I cut far too close to the diameter of the tube, right at the part where the blank is most translucent.
One small step on the pen, makes a whole new outlook to mankind. Nice job !! Next time paint the inside of the cap or tube. Jim S
Can't you just remove the cap thingy and give it a 'touch up'? (Not having made one of these kits, I just don't know if that's possible....figured I'd ask)
Scott (nice coloring) B
No, it's a valid enough point... if I'd just turned the knob up and drilled a hole in it! I thought I'd be clever, though and I glued an 8mm tube into the twister (as you would a 2-piece pen) so it could be excahnged with the original without modification of the pen.
So no way of touching up the tube. Let's face facts: I cut the wall of the twister too thin!!
