Looking For----
Does anyone have a source for some colored acrylic "L" shaped angle trim pieces. At least 3/4 by 3/4" any length. Looking for many colors. Has to be a 90 degree corner. No rounded corners. Thanks.
If this outfit doesn't have what you are looking for, They have something close. All types of frame types and styles along with all kinds of things you never knew you might need. Great one stop source for plastic, hangers, display and architectural trims etc. Outwater Plastics Industires
They only drawback is they have very,very large catalogs that total thousands of pages, the index was a separate catalog back in the day :wink:
:clown:
:clown:
They are limited on colors but I sure did file that link to my favorites. Man they have a ton of stuff. Thanks
I may be way off, but couldn't you just use a pen blank? Run it through a dado blade on the table saw leaving an "L", and go from there. Hope this helps.
Dave
Dave
Can do Dave. But that is alot of work if they are available already and that is or would be alot of waste to do what I want to do. I may do that if I want to try a blank with a more funky color scheme.
