The technique describe in this tutorial will work with mostly any inlay material
Inlay Turnings
That's pretty much the technique I use except for one main thing. I reverse the steps in applying the inlay material and glue. I use PearlEX powder. If I fill the voids with the powder and then try to apply the glue, the glue just clumps up and runs off and doesn't actually absorb into the powder, (regardless of thin, medium or thick). So I turn to pretty close to the final shape and then put a few drops of medium CA and already have my powder ready to "sprinkle" onto the CA. Then I use a piece of cardboard to spread the mixture into the voids. If a blank has alot of voids this may take several applications. Once it's all filled I make the final cuts with a carbide cutter and start sanding to remove inlay from around the voids.
