Mike
Something looks odd. Not sure what you mean about leaving 1/8" material at the top of each cut. Is this suppose to be a multicut knot?? No. In other words 2 knots together??? Did you follow the instructions in the library??? What did you cut with (tablesaw and thin kerf blade) and did you use the cut all the way through method No. or did you leave material (left 1/8" material) and just fill the void??? Did the fill material match you saw kerf exactly??? I made a test cut and filled the kerf with veener until I could not get anymore in. Something is definetly off. It looks like you skiped a cut or rotated the cuts improperly. I marked each side 1,2,3,4 and rotated it after gluing in the fill material and sanding the sides flush.
