Python blanks
Bayward
Tampa Bay area
I am not sure the Python skin pattern will make a good blank for something as small as a pen. The pattern on a Python skin seems it is too large ?
I have tossed a few Pythons in the trash barrel for pick up in the past. I used to live in South Florida, now Tampa Bay area.
Here are some skins for sale.
Bob
Kenny Durrant
Sachse Tx. 75048
They have babies that are small enough to make pens. I also found that you can shrink a skin quite a bit with heat. I had a skin that was wrinkled so I had the idea to iron it to smooth it out. I laid out the skin and put a damp paper towel over it and as soon as the iron started warming up, not hot, I pressed the skin and it shrunk. The pattern looks better but it gets a little thicker also. I do it often because on the larger copperheads the patten is too big and you can see through the skin. I had a large rattlesnake and was able to put it on a slim pen with no problem.
