Jeff Leslie
I have just gone back to class and started turning pens. A long way back from turning boxes and platters, but a large and steep finishing / learning curve in any case.
Having done some work already with CA, I was more than interested in seeing how the glue would come up as a finsih against poly and nitroceluose.
I practiced with CA hard on a variety of Oz timbers, incliuding beefwood, fiddleback redgum and blackwood. The results, as expected, were great.
But all that testing was done without bushes! (And yes, I have ordered the right ones now!)
At this early stage, it seems to me that, as with all finishes ""ënding"" on a point, the main problems with CA and any hard finish are:
- clean breakage on the join after curing (with or without sealing the bushes)
- sanding though the finish back to bare wood at any stage
- deciding on whether to use thin or medium CA
- estimating the % of build up of finish over the bushes prior to them being sanded down
- production runs where poly or spraying might be a better option
We are no doubt fortunate here in Oz with such a wider variety of timbers to use - and many of them hard and colourful. But I am still not sure whether to get the NC spray out and avoid the CA route altogether. Problems dealing with spraying a volume of barrels is a given. Same amount of fumes, but different.
Ideally, I want a finish that I can complete either in batches or separately, but it must be worthwhile. A hard wearing floor finish applied to blanks on a modified and extended mandrel seems a good alternative at this point. Ideas and thoughts welcome.
CA remains an essential part of my turning journey, particularly on burl and highly figured pieces. So don't dismiss my liking of the merits of CA.
I want to hear from mass / production pen turners that have done the sums - as well as those that have not. Learning from all sources is the key. I have seen countless clips of CA finishes but none where the alternatives were an option. Give me your thoughts, particularly if you spray as a matter of course.
