Cebloplast, show off what colours you have or used?!
philb
Midlands, United Kingdom.
Hi,
Just a fishing thread to see what colours or types of Cebloplast people have in there special stashes or or cebloplast they have previosu used!
Just being nosey really, as i've only seen about 4-5 colours (Serpentine, Celebration, Blue Ice, Granite/Grey chip and a Red/Orange Chip one?)
PHIL
Here is an example of the blue and red and also of the black iced
Here is one that I did, It is Blue cracked ice cebloplast. I drilled it on a metal lathe because the rod is only 16mm and the jr gent cap drill bit is 12.5 mm. So it was pretty close.
The rod you have, good luck finding anyone willing to sell it! It's hard to find and harder to buy. Some other colors of cebloplast are more readily available and can be found at a number of sites: Exoticblanks.com, Indy-Pen-Dance.com, Theclassicnib.com, and richardgreenwald.com. There might be others, but those are the ones I know about.
It turns easily, but the biggest worry is HEAT. Any heat buildup while drilling or turning will cause it to melt. If you want an example, take it to a bandsaw and cut off a small sliver. You'll see how it reacts.
Here are a couple pens made from some cebloplast that I was told goes back to the 50s:
This is black with blue and red flakes.
attachment.php
This is very dark blue with light blue starburst sparkles.
attachment.php
These are some pictures of other rods from that batch:
attachment.php
attachment.php
Cebloplast
These are some older pens, all of which I posted here at one time or another. I still have some of each of these patterns.
