Pool cue style rings
mpex
Columbus, Ohio
Any ideas how I might make rings something like these? This is actually what got me interested in pen turning. I own a beautiful Southwest Cue, Jerry Franklin era, Purple Heart and Ebony. I always wanted to make a pen to match.
It's called segmenting.
Lin.
Lin.
I should have said originally, I know it's segmenting. I've already started doing some simple segments but have no idea how to do something this 'complex.'
Thanks.
Lin.
Thanks.
Well it really is all the same, but as you said more complex but if you think about it on a larger scale to start with and then just scale it all down. So like those rings you can put it altogether turn it round and then cut the rings off the size you want them and then sand and glue them where necessary.
Lin.
I tried something like that. In principal it is easy, in practice well I needed a better protractor, or better eyes or something. I could not get the angles right. Look up segmented turning on the net and you see some super cool stuff as well as some programs to help with angles to buy.
It is doable
Here is a harlequin pen I did a while back, may give you some ideas on little squares, lines are simple inlay slices. This one was one of my first and that that accurate, but you get the idea.
Hope this works, the photos are from another forum.
Cheers
It also helps to have precision tools and lots of patients. I think HF has a cheaper version and not quite as accurate, but here's a tool that will assist in what you're looking to do and is probably one of the best quality machines out there.
Byrnes Model Machines Home Page
Hope that helps get you down the trail and into some segmenting.
Here's a segmented one I did that has some of what you are looking for. It was pretty easy.
Thanks for all the comments! That is giving me a lot to think about. I've been watching some pool cue turning videos on youtube which has also given me some ideas. I need to get through the holiday season before I can start working on projects for myself...
