BradG
Im aiming on picking up a new lathe around june, and have my eye on this one. Wouldn't mind peoples thoughts on it if anyones familiar with it? Mike the supplier which had your model no longer seem to be offering it, though this one looks similar, i cant say if its the same one under a different brand etc without comparing all the specs..
My budget in an ideal world is around £2500.00, and this is being offered by chester machine tools. if anyone can recommend a UK lathe dealer id be happy to take a look at theirs too
Centre Height150mm
Maximum Swing300mm
Swing over Cross Slide178mm
Swing in Gap430mm
Length of Gap220mm
Distance between Centres810mm
Width of Bed185mm
Spindle Bore38mm
Spindle TaperMT5
Spindle NoseCamlock D1-4
Tailstock Quill Travel100mm
Tailstock TaperMT3
Cross Slide Travel160mm
Compound Slide Travel85mm
Saddle Travel600mm (with leadscrew guard)
Number of Speeds18
Metric Threads0.4 - 7mm in 26 Steps
Imperial Threads4-56 TPI in 34 Steps
Saddle Feed Range0.052 1.392mm/rev, in 32 Steps
Cross Feed Range0.014 0.386mm/rev, in 32 StepsMax.
Tool Size16mm
Motor1.5 hp
Power240 or 415volt
Net Weight450kgs
Dimensions (LxWxH)1780x650x1160mm
FEATURES:
Centre Height150mm
Maximum Swing300mm
Swing in Gap430mm
Length of Gap220mm
Width of Bed185mm
Spindle Bore38mm
Spindle TaperMT5
Tailstock TaperMT3
Number of Speeds18
Tool Size16mm
Motor1.5 hp
Power240 or 415volt
Net Weight450kgs
FEATURES:
- D1-4 Camlock Spindle
- Hardened & Ground Bedways
- Independent Leadscrew and Feed Rod
- Gap Bed
- Taper Roller Bearings
- Cast Iron Bed
- 3 Jaw Chuck
- 4 Jaw Chuck
- Fixed Steady
- Travelling Steady
- Splash Guard
- Machine Stand
- Leadscrew Guard
- MT5-MT3 Sleeve
- Quick Change Toolpost
- Toolholders
- 2 x Steel Centres MT3
- Manual And Parts List
- Machine Lamp
- Foot Switch
- 2-Axis Digital Read Out
- Coolant System
