Variations on a Theme
See more from Ed McDonnell
Ed McDonnell
Melbourne, FL
After making the MIMO pen (laying down in foreground) that I had showed a couple of days ago, I decided to explore what I could do with black lines and red dots on a white background. I had dozens of ideas. These are the ones I decided to make before I decided it was time to move on to something else. Triple casts. White, black and red.
Ed
Thanks for the compliments.
As to the how, it's conceptually pretty simple.
1) Cast a solid color blank.
2) Turn the blank to size and shape.
3) Carve a design in the blank.
4) Cast the blank in another color.
5) Turn the blank to size and shape again.
6) repeat steps 3 to 5 as many times as you want.
While the concept is simple, the doing requires a fair bit of skill. While these days I use some fancy tools I've made for myself (see my previous posts on my DOL (Digital Ornamental Lathe)), a lot can be done using hand tools (and some patience). All you need is a lathe with indexing and some very simple jigs. Of course good turning skills and luck come in handy as well.
Ed
I have no clue how you do that. looks like a lot of work. Very neat.
Those are great pens!
My guess as to how it's done:
1. Cast white cylinder/tube
2. Cut lines, cast in black.
2.5? Turn off extra black so you can see where the lines are for alignment in step 3.
3. Drill holes, cast in red.
4. Turn and finish.
Am I close?
(Edit: yes, I was. The actual answer was posted while I was writing this.)
Good guess Matthew!
For anyone really interested in creating these types of designs by hand I would recommend finding a copy of "Turning Lace Bobbins" by David Springett. He did both a book and DVD. Your local turning club may have a copy in their library (or you might convince them to get one).
He has some clever ways of creating designs on small diameter cylinders by hand. Easily transfers to pens.
Bobbin Book
Ed
Ed
Wow! Now that's a process.
