JD Combs Sr
Have seen some of these on here before and wanted to try my hand at them. Ordered a bulk box off Amazon(cheaper by the dozen
), these were some very small ones. The thing that I didn't realize was how fragile these things are
. I broke three before I even went to work on them.
Worse then working with egg shells.
To make the urchin a little more durable I poured about a 1/2 teaspoon of medium CA inside it and repeatedly turned the Urchin so that the CA coated its entire insides then hit it with accelerator. I could tell that it added a little weight to it but nothing major. Definitely felt sturdier.
The complete ornament is about 5" with a diameter of 1-7/8". The urchin is only about 7/8" thick. Finial and icicle are Black Cherry. One coat of CA as a sealer on the Cherry then the whole thing was sprayed with Deft lacquer after assembly.
Another thing that I had not noticed on other Urchin ornament posts was the "saddle" shape at the larger opening, top in the photo. The 2nd photo shows a differnt angle and makes it look non symmetrical. I may reverse the orientation of the urchin in the next on and see how that looks like.
As always C&C welcomed.
