vfauto Member Joined Feb 27, 2012 Messages 56 Location Ma Nov 21, 2012 #1 I would like to cast coffee beans and my first attempt failed.If anyone has experience with this can I get detailed instructions? Thanks Frank
its_virgil Member Joined Jan 1, 2004 Messages 8,492 Location Wichita Falls, TX, USA. Nov 21, 2012 #2 Hi Frank, Have you searched the casting and stabilization forum? Searching on"castng coffee beans" gives this: http://www.penturners.org/forum/sea...=1&photoplog_searchquery=casting+coffee+beans Other serch strings may get some other results. Also, there is an artricle in the library that will help. Do a good turn daily! Don vfauto said: I would like to cast coffee beans and my first attempt failed.If anyone has experience with this can I get detailed instructions? Thanks Frank Click to expand...
PTownSubbie Member Joined May 15, 2009 Messages 2,229 Location Chesapeake, VA Nov 21, 2012 #3 Frank, There is a decent search function if you give that a shot. These are some threads that come up if you search "coffee bean" in the casting and stabilization forum. http://www.penturners.org/forum/f43/coffee-floats-61396/ http://www.penturners.org/forum/f43/coffee-bean-stabilizing-how-long-95030/ http://www.penturners.org/forum/f43/casting-coffee-beans-93421/ That should help you start. See what else you can find in the search function.... Fred
ed4copies Local Chapter Manager Joined Mar 25, 2005 Messages 24,806 Location Racine, WI, USA. Nov 21, 2012 #4 Also we can be more help, if you tell us WHAT failed!! Did it not gel? Did all the coffee beans float to the top? In short, a more specific question will get specific answers. Hope this helps!! Ed
