Quill retraction
wkuhn
Columbia, MD.
Recently while drilling 24 pen blanks on my lathe, I was wondering why no auto quill retraction? Maybe spring loaded like a drill press or maybe motorized. That's when the light bulb appeared above my head. I grabbed my trusty inner tube a cut a 1/2 in section off, put it around the hub of my quill handwheel and put the other end into my battery drill, voila a motorized quill retracter with zero mods to my lathe. My quill traveled smoothly enough so this worked like a charm. Clean and lube your quill and give it a try next time you are drilling pen blanks. Keep in mind I did pull the tail stock and bit out of the blank before retracting.
Wayne Kuhn
Columbia, MD
Isn't holding the drill with the correct tension and pulling the trigger more effort than turning a wheel?
Absolutely not. The fine threads on the quill make retracting it 2+ inches is a pain. Holding the drill with tension is really quite easy. All I can say is try it.
Don't you have to set up the drill/band combo every time?
It kind of seems like the solution is more complicated than the problem, but I'm glad that it's working for you.
