I have no idea how toxic the smoke that you mention is. I do not get any smoke. Do you have a typo in your message or are you really cooking the blanks at 200° CELSIUS? If this was not a typo, you are cooking them WAY too hot! If you meant Fahrenheit, then you are at the correct temp but 150° F will not properly polymerize the resin. If you are indeed using Celsius, then the proper cure temp is 90° C.
Holy SUGARRRRRRRRRRR, mate
, why in a hell did I not realise that the 200° you mention in your web/videos, etc., was Fahrenheit and not Celsius, I should have remembered that you guys use F in your temps, bloody hell, no wonder why some woods looked a bit too cooked, reason of my extra foil protection above and bellow the heating elements.
I find it totally amazing that I have mention you system and the cooking temps to set the juice, here (a few times) and elsewhere where the 200°C were constantly mentioned and the only observation I had was that, at those temps the wood would need the foil for protection from burning, but most people accepted it as OK so, I'm annoyed, mesmerised, surprised and glad that, such temps are indeed just to damn high for wood, with foil or not, period...!
This may serve as an example, not so much for the guys in the USA and I believe in Canada where, the unit of heat measurements is Fahrenheit and not Celsius like us here in Australia and most European countries so, for those like myself in the Celsius world, the correct temperature to set/cure the Cactus Juice is 90°CELSIUS or 200° Fahrenheit...!
My observation to Curtis is, if I have been wrongly convinced of the setting temperatures, for all this time, with the amount of reading and video watching, means that some how, the info in not totally clear or explained in such way that, would leave no doubts to what the correct temperature is, in either Fahrenheit or Celsius.
As soon as I have the opportunity, I will try to go through the info on your web site and see those videos again and see where I went wrong and how easy or not the confusing may/have/will occur to other also.
I'm sure that, you have provided the correct information for the product, and you probably though that, no silly bastard would cook their stabilised blanks at 200°C, maybe so but, if I made the mistake, other may do the same.
If it turns out that, no one has even considered the 200°C for the curing process, I should maybe request to be put into the World Records Book for...!!!! yeah, something like that, thanks...!:redface::biggrin:
OK so, if the smoke was caused by the juice "burning" in some way, and you have never experienced it, makes sense however, one thing that I've noticed is that, most of my blanks/woods come out with the same dry juice "crust" as those you show in your videos and the way I would expect anyway so, my next question to you is this, the dust produced from sanding the stabilised blanks/wood, is it toxic, is there anything in the juice composition that would make it more dangerous when sanding than, the risks of inhaling any fine sawdust...???
There is obviously a lot more than fine sawdust, the harden juice is sanded down into very fine particles that mix with the wood when reaching the woof surface so, I'm not advising anyone to sand them, without some sort of a breathing apparatus, my question is, will a "normal" dust musk be sufficient or, there are chemicals there that require a better breathing safety apparatus...???
Then and again, most folks would say that, they only do a few at the time so, the exposure to its sanding dust isn't a big deal however, I would disagree with such statement, I do a lot more than a "few" at the time,. 100 blanks is my vacuum chamber capacity, and I like to save on power as much as I can so, stabilising and cooking items, have an identical capacity...!
I don't expect you Curtis, to know everything however, I would expect you to find out, for all of us sake...!
Cheers
George
