Wright
Will Silmar 41 PC clear have any bad effect on fabric? I thought once I saw a thread where someone made a pen out of denim.
In addition to Shawn"s one try googling the denim micarta type of handle slabs. There are a number of vid's on it Knife handle from denim and fiberglass resin - YouTube
:clown:
I have made many watch pens using fabric on the tubes.I have never had a problem with it.Like John said you just have to worry about the seam.But since it is a watch pen I just use the pieces to hide the seam.
Here are a couple photos.
Denim Photos - Blanks
Toasted
A picture is worth a thousand words.
The blank I turned and #3 I added some translucent blue dye, just a little when I rolled the material. The #1, I just cast in clear but I have not turned yet although it appears pretty much the same color by the looks from the cut.
The blue disc is the leftover from the cup that was still liquid 24 hours after mixing. It sat in the shop at 30f overnight. I put it in the oven at the end of the 2 hours that I heated the blanks, 150-175f and it is fully cured. It was probably in the oven for 30 minutes.
The blank #2, I just rough turned the blank and sanded and put a little CA/BLO finish on it. I plan to use CA on the ends after squaring, and then go into a multiple CA sand regimen to impregnate the CA. Right now with just a rough finish, I can feel the denim. It's tough but just has the denim feel to it.
The CA fumes really kicked on this material.
