Ed McDonnell
I was looking for a quick and easy way to secure the clip in an invisible mounting. Using CA means waiting a long time for it to cure to insure you don't end up with a film deposited on your nib and section. Using epoxy is a hassle because of the potential for it to leak out of the slit for the clip onto the exterior of the cap. Also the potential for it to end up where you don't want it inside the cap as you try to get it down to where the clip is.
I decided to try using poly clay to secure the clip. Dropped little balls of color matched clay into the cap and tamped them down with a close fitting rod. The clip stays where you want it with the clay packed in. Cooked the cap to set the clay.
Worked great the first two times I tried it. On the third, the PR resin on the cap cracked and buckled. I'm pretty sure I used the same temp and time to cook the cap (as close as you can get on a cheap toaster oven). 33% failure rate is too high.
I think my next attempt will be to try some epoxy that I thicken to a putty with a filler and color to match. Use the same process as the clay, but without having to cook the cap.
Ed
Ed
