A Table Saw Story
Fibonacci
Ridgecrest, CA
I have been using a bottom of the line Craftsman table saw for the past few years and really being unhappy with it. When I picked it up, it was what I could afford and it sufficed for my needs of the time. It died a few weeks back. One part of me was glad because I had an excuse to buy a new one, but part of me was sad because I still couldn't afford the one I wanted.
While saving up for a new one, I happened to run across a 1953 Craftsman contractor saw on Craigslist about 8 hours away. I thought it looked like a good deal, but was much too far away to get. I pointed it out to a friend of mine who, it turned out, was driving past there with his truck a week later. I made some calls, secured a deal, and he picked it up on his way past.
When it showed up, it made horrible screeching noises, but basically worked. I spent a couple hours doing a cursory clean and lube, determining that it was just a loose belt and a cracked pulley making the noise. I decided to pull the pulley to fix it and discovered the bearings in the arbor were dragging just a bit. I checked the run-out and decided the bearings were currently good, but did not have much life left.
To make a long story shorter, I debated whether to spend more money now and replace the bearings, or just move forward with it as is and replace them when they failed. Now the saw is spread out across my entire work table and I am picking out powdercoating colors...
We shall see how my first major tool restoration turns out as it develops.
Bearings are usually pretty cheap if you order them by size and not from the maker with OE part numbers.
Basically all you need are width, ID, OD, and type of bearing to find what you want and they are almost always just standard stock sizes.
I guess I didn't make it clear, the bearing are out for delivery today. I decided to do a complete restoration rather than mess with a simple cleaning.
Obligatory before pictures.
It doesn't look great or bad, but it could use some love and it howls like a banshee.
Here is its current state. The motor runs and sounds great, its pulley is fixed and polished, and the new bearings showed up.
It is going to sit like this until at least Saturday because my son turns 3 tomorrow and we are going to spend most of the day at the park.
I will update as things progress.
The bearings should be YOUR FIRST PRIORITY. Besides putting you into an unsafe working condition, when the bearings decide to "let go" they could cause you motor to seize, leaving you with another saw not worth repairing.
I agree, do the bearings. They will cause more problems later on, if not out right get you hurt.
I have a Craftsman similar but newer, circa 1976 that I still use. Replace bearings, tune up and Get a better fence! If you want to do accurate cutting, a new fence and a high quality carbide blade are a must. Thought about buying a new one but it still works good for all I need. You might want to upgrade to a linked type belt, they run smother, quieter and deliver more power to the blade which you need for thick rips.
Well, I couldn't sleep last night, so I got ambitious.
The new bearings are in and everything is cleaned/dry lubed except one piece of the arbor. As a side note, I discovered that only one of the 6 bolts holding my trunnions on was more than finger tight...
The main saw is done.
There is .006 runout on the blade (diablo that I have been using for a few years) and .004 kickout along the length of the miter slot.
I have not squared the new fence yet, but she sure looks and sounds good. I plan on building a cart with a router table for the space between the rails next.
