Good Pen Press?
turnin4fun
Madera, CA
Hi I am fairly new to making pens, I have been thinking about getting a pen press, does anyone know which one is better?
Thanks in Advance!
Here's mine. A little pricy at $700, but it does a few other things too! :)
A drill press is a good option. Another is your lathe. In my case I've used several pen presses but my lathe is by far the better option for me. I simply turned two pieces of plastic
to a #2 MT and insert those in the head stock and tail stock and use the tails tock quill to press in the components. The plastic is the same material used for manufacturing cutting boards and I purchased it from Tap Plastics for around $5.00.
When installing transmissions in some kits where depth is critical, the quill shaft gives me the fine adjustment required when seating these components plus it's one less piece of equipment that I have to have.
From a whip finisher in fly tieing to the thousands of useless gadgets that are tauted as must have hunting aids every pass time I know of is full of overthought usless crap that costs twice as much as it should. Inevitably I go back to the way of doing it that has worked for years. In other words I buy the new hotness so it can sit ain a drawer while I go old school. I have a press. used it maybe 6 times.........it's a great dust collector!
Here is what I actually use! And I have never broke or bent a pen with it.
I've tried some of the "purpose made" pen presses and have not been happy with them. About 18 months ago, I read about someone using a Zyliss bench vise as a pen press and they had great things to say about it, so I bought one off of Ebay and absolutely love it. Super easy to control the amount of pressure and can be moved to sit whereever you want it. I've also used my lathe as a press, but found this to be much easier and convenient. Here's one on Ebay starting at $30
http://www.ebay.com/itm/VUNDER-VISE...910?pt=LH_DefaultDomain_0&hash=item27cb42fa8e
Just a thought...
Jim Smith
I remember seeing this vice 25 years ago at the home improvement shows and never did buy one but I always wish I had for different projects around the shop. I may have to bid on this one. Thanks for posting the link Jim.
VUNDER VISE (ZYLISS) WORK TABLE VISE CLAMP FROM WORK SHOPS CAST ALUMINUM | eBay
Just a thought...
Jim Smith
Like Rick P, I use a quick clamp but I'm thinking of getting an arbor press like this one from HF but I'll use it for other stuff too.
I'll probably still use the quick clamp 99% of the time.
I have several presses, including the arbor press and one each of the manufactured pen presses. They all sit in a box, unused.
I use, almost exclusively, a Zyliss Swiss made workbench clamp. It is the most versatile tool that I own and works flawlessly as an exacting pen press.
When I am on the road and need a pen press, I use an Irwin Kwik Clamp. It works better than the manufactured pen presses that I used.
Here's one a "student" brought to class.
WB
