Thanks for the kind compliments!
In answer to 'how?' regarding the pillow, I'll try to be brief (I'm currently up north with poor internet access, my iPhone is my computer)
Take a 2" piece of acrylic, turned to a dia. That will fit in the collet, eg 3/4" (need collet chuck). Turn each end very flat. CA a waste piece onto each end. At least one will also have had to be turned to 3/4" already. Mount one end in collet, the other end supported by live center. turn the piece to just below desired dia. (eg 5/8 or 1/2). Shape the piece as desired ( in this case, round ends) but without parting off yet. Turn a groove in the middle. Sand with successive grits 400 to 12,000, and polish. Part it off. Wrap a few turns of masking tape around it so it fits snug in the collet, but leaves the unfinishes ends exposed. Finish turning, sanding and polishing the ends. Repeat for orher end.
Now unwrap. You should have a nicely polished peanut.
Next sand a plane onto it with a coarse beltsander, while trying not to lose your fingertips (could also use a disc sander lathe accessory). Then finish sanding the flat plane with successive grits on a very flat surface, up to 12,000, and polish.
Done!
Hope that was comprehensible. Doing this on an iPhone sucks
Happy turning!
Ken
