Sketch plan specs.
Jgrden
hOUSTON, Texas
I need some lead time on pens made as awards to an event this weekend. The PennState order will not be here until Thursday which is cutting my time very short. I can turn the blanks ahead of time with the specs. How do I get the specs ???
Hopefully the instruction sheet has the drill sizes and bushings that you need. If you have the tubes you can go ahead and turn blanks. Without the tubes I think you are probably out of luck. Depending on the component set other tubes may fit. I think somewhere in the library there is a cross reference table for various tubes etc.
unless the kit is a new one since this came out you should find the infop here: http://content.penturners.org/library/general_reference/bushingsandtubes.pdf
If not, ask for specs for the pens you are making and I'll bet someone will help you with them.
Do a good turn daily!
Don
Don
I was able to get the instruction sheet off of Penn State Industries. Now I can begin without the kits. Thank you for your help. I had downloaded this spec. sheet before and keep it with my bushings.
