Convert Roller Ball to Fountain - Churchill
Jgrden
hOUSTON, Texas
Probably a dumb question. I wanted to complete a Churchill Sterling Silver fountain pen. When I checked my inventory all I had were two Sterling Silver Roller Ball, which is not what I want. Can I order new replacement nibs that will REPLACE the roller ball components? Nib, feed, housing. I do not see these listed at the Arizona site where these were purchased.
Your advice is solicited.
John:
You either have to make or buy a front section to replace the roller ball section.
I know that MRedburn makes a lot of silver pen parts. He may be willing to make you a sterling Cambridge section, if you don't have silver or the tooling to make the section.
If memory serves me correctly, the Cambridge uses a 10 x 1 thread set. If you make the section, Berea sells the nib and feed individually.
Ir I recall correctly I think the el grande front section will work on the Churchill. It will be on the Arizona Silhouette site but listed for the el grande.
Ed may have that section at Exotics.
Do a good turn daily!
Don
Bear Tooth Woods also sell a Cambridge section, but it is black, not sterling, and the same section as the El Grande.
Hmmmmm looks like I need to order a new pen kit. Anyone want to trade two sterling roller balls for one fountain pen????
Pic from the Berea site
As far as I know, the section is black for the Churchill as well as the Cambridge so this is the one that you want
I just checked a Sterling Silver Fountain---Jeff is absolutely correct!!! And, no Exotics does not offer this nib, but I believe Bear Tooth does (Arizona Silhouette probably does too, but for the moment, let Barry stock his inventory before asking for 'pieces"!!)
