skamrath1
Where can I purchase a 10.5 and a 12.5 brad drill bit if there is such a thing.
I got mine at either PSI or Rockler I can't remember which.
I don't know why people insist on having these (expensive) metric drills. Get a good set of regular drill bits, measure the tubes, and use the appropriate bit. The set I have came from Harbor Freight, contains all bits from 1/16 to 1/2 (by 1/16ths) and was quite reasonably priced.
I assume this is in metric? I would urge you to *NOT* purchase single bits as they are more expensive than a full set of bits. You can get the 115p set, full letters, full numbers 1/16 to 1/2" and a caliper, you will be set for a good number of years.
115 Piece High Speed Drill Bit Set w/ Drill Index Not bad for $35.99
If you have a HF close to you, then there is probably a 20% off coupon in today's paper. Take that with you.I assume this is in metric? I would urge you to *NOT* purchase single bits as they are more expensive than a full set of bits. You can get the 115p set, full letters, full numbers 1/16 to 1/2" and a caliper, you will be set for a good number of years.
Thanks I am going there today to get these
