Who was making the washer/clamp plate/position plate for tail/tool rest?
warren, michigan, USA.
I thought I seen someone on the IAP making the washers/clamp plate or position plate for the tail stock/banjo?I have a rikon mini 70-100 and want to make a sphere jig for it and want to make it easy on my self and buy a couple of these washers/plates(what ecer you want to call them).I will call Rikon monday to see what they want for them,but also would like one that is better made.My tail stock is a little off unless you twist it forward when you tighten it down,so I think it needs this centering washer made more precise.Anyone with thoughts/ideas/sources?Thanks,Victor
Lee Valley sold the as a "Clamp Block" when I got one for my Jet -- may fit a Rikon.
They are the oneway brand for the steadys but work for the tailstock on the jet midi -- and you will need to know the space between the ways to select the one to fit.
Under $15
