Drstrangefart
Here we have a Firewhatfire blank on a Cigar. I had intended to almost double the length of the top barrel to see what would happen, and I made a goof. Got myself set up with a short tube for the bottom barrel. I caught it in time to swap barrels out after cutting the would-be top barrel down on the bandsaw. It was still too long when I finished, so instead of taking it apart and re-working it, I just figured out a way to stretch a lower tube easily. Turns out you can glue a dowel into the plug in the transmission that's the right length to make everything work right and you're in business. I'm pretty sure an old coat hanger would work just fine. I used a dead Dremel drill bit. Sorry if the blue backdrop makes the pic rougher than usual. It didn't quite work out on a white backdrop.
