Interesting super close up pictures of stabilized and unstabilized wood
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
I bought a USB micro-scope camera to play around with and decided to see what stabilized vs. unstabilized wood looks like at 200x magnification. The wood is spalted pecan and the pictures are taken of the end grain on a couple of cross cut blanks. Both blanks came from the same board and both were cut on the same 40 tooth Tenyru blade.
The first pic is unstabilized and the second is stabilized.
attachment.php
attachment.php
Great pics Curtis and certainly a well worth investment those USB micro-scopes, I've used mine in many situations with surprising results, always...!
This test is quite demonstrative of the action of the "cactus juice" but, I would suggest you repeat the test but this time on the centre surface of a stabilised blank Vs an identical non-stabilised one. The objective would be to see the penetration results of the solution at the furthest point from its surface.
The reason to this test is that, the surfaces you used on this test are exposed surfaces, therefore under reaction from the oven curing process and air so, compare that with un-exposed surfaces where the solution penetrated, will probably give you a very different set of pics to compare.
Curiosity is the reason to my quest, as curiosity was the reason why you got the USB scope and done this test so, you can play around a little more and waste a stabilised blank by slicing it in half and see what the scope sees....!
Have fun...!
Cheers
George
The advantages are clear. Magnification sure speaks volumes as to the differences. W/O looks like cotton balls or fluffy carpet. The bottom looks like a 72 tooth cut.
Thanks for taking the time to do this and post it.
George,
This is pretty much what this blank shows. The stabilized blank started out as a large test blank that was 2" square. After getting the weight data I was after, I decided to cut it up into pen blanks so what you are seeing IS the inside of the larger blank, not the outside of a normal pen blank.
Thanks so much for posting.....I'm a Noob at all of this but I have trouble visializing without the benefit of Hands on as when someone explains something via the Web/forums and this makes things so much clearier to understand about stablization.
George,
Curtis,
Thanks for your explanation, was no way for me to tell if the photographed surfaces were outside or interior surfaces, that makes the test even more plausible and clear...!
Thanks,
Cheers
George
thanks for the pics, they came out very nice. actually you could enalarge,frame and hang them on the wall. Could be an interesting side job, unique enlarged photos of peoples favorite things!!
May pay for the equiptment.
