How to get the right length?
I received a PM question on how I fit the tranny to the case and got the right length for the refill. I am posting my answer here so others can see and also posting some more photos.
"I turned down a cigar center coupler(available from
Wood-n-Whemsies) to fit a 5/16" hole i milled into the case through the primer. I pressed it in incrementally until I had the right protrusion of the refill point."
Edit: Just a note on the case. The case was from a fired blank. The blank was the type with a crimped end where the bullet would normally be. The crimping and subsequent re-straightening of the neck usually splits the neck length wise at several of the crimps. I turned off about 3/32" from the end of the neck to remove much of the splitting before resizing the ID of the neck. The resizing not only narrows the neck down to the SL nib tenon but soldering of the tubes reinforces any remaining splitting. Removing the 3/32" also allows the couplers first shoulder after its threads to be pressed into a near flush line with base of the case when using the slimline nib.
Hope this answers the question and is helpful to others as well.
This is the unmodified cigar center coupler that the tranny screws onto. My apologies for the out of focus pics.:redface:
I screwed the coupler into a tranny then chuck the combo up in a collet chuck on my metal lathe. The coupler is brass so it could be done on a wood lathe as well.
I turned it down so that it was a press fit into the 5/16" hole I milled into the brass case. (BTW I say milled because I drilled it on my metal lathe
using a 5/16"x60* center drill. The few times I have tried a jobber or other bit the hole was not true and centered even if I started it with a pilot.)
