watch_art
I had asked a while back about doing finials and clips, and gotten different bits of advice.
Here's what I'm doing now.
Drill out the cap 55mm with a 23/64 to give room for the nib.
Drill 5mm deeper with K bit, give or take, to 60mm for the threads for the finial. 5/16" threading will go there.
Drill out to 17/32 and thread 9/16" - about 14mm really.
Then drill with 19/32" to kill some threads and allow part of the barrel to be hidden by the cap.
Turn the pen to shape, with the finial end about 15.5-16mm diameter so I have room for a lip to hide the edge of the clip. Or I could turn it to just under 14mm and let the whole clip ring show like on that blue one I did the other day. If I do that I need a little raised lip on the cap side to hold the clip centered on the cap. Easy to do.
So get the cap turned and cut it off, turn it around in a collet chuck, and turn off some of the end exposing the hole and thread 5/16", then take off some material around the threads to allow the finial to seat against the cap, and then cut out a little recess with a wall around the edge for the ring to sit in deep enough so the finial will snug down against the cap and not leave a tiny gap.
I think that covers it all.
Thought I'd share.
Comments or criticisms welcome. I can use all the help I can get.
Cheers!
Thought I'd share.
Cheers!
