Pen stands, show displays
NewLondon88
Local Chapter Leader
Claremont NH
Hey Ho..
haven't been on much in the last few months.. other things going
on, but a few have asked if I'm still making stands. So here they are:
3-Tier stands:
These hold 3 pens, rising front to back. You can get them either with
a rectangle or a trapezoid shaped base. I ship clear acrylic by
default, but have some smoky gray/brown and mirror if anyone
need that. $6.50 ea. (add $1 for mirror)
The 2-tier is almost the same as the 3 tier, but holds 2 pens.
The barber pole is a razor stand (for those who do razors and shows)
holds 5 razors. The sides are sandblasted for a frosted look. If someone
wants these for shaving brushes, I can adjust. $20 each. You can add
your name or logo to the base
The tree was an idea for pendants, keychains, earrings and such.. things
that hang . The parts interlock and there's a square ring at the top just
to make sure it holds together. Pretty stable. Doesn't have a base, since
it would make it too expensive, but i can supply a template for the foot \
holes. Or I can get the material and make a base if you want. I just feel
bad that the base would be about as much as the tree! $30
The large stand holds 18 pens. The three shelves hold risers in the center
and slide into the large sides. Slides together easily and comes
apart just as easy if you want to pack it up after a show. $50 for the
large display stand with clear shelves and black sides. You can add
name or logo if you want, price depends on the artwork.
(thanks for the photo, Lenny!)
http://photobucket.com
The shelves are good for displaying a lot of small items at a show. It has
3 shelves 20" wide x 5" deep and they have pins to hold them in place.
You can put a back on it if you want. A dark cloth works to keep the
focus on the items instead of staring through the shelves. $60 ea.
The last one came to me from Jon Piper. He wanted something
a bit bigger than the single pen stand, but wanted the pen tilted
and standing up. So he drew it out and sent it to me to try. Came
out pretty decent, if I do say. The top of the large post is bent to
hold the top of the pen. The bottom post is bent at the base to
hold the nib. Comes with extra bottom posts because some will
place capped pens, some will place sierras or slims.. and the
nibs are different sizes. So .. extra posts with different size holes.
$12 ea. I'll take off $1 if you want to bend your own acrylic
Shipping is whatever USPS charges.. but I try to stay with at least
the small flat rate box. Otherwise things tend to get broken.
Drop me a PM and I'll get them started!
I'm running a 30w Mercury. Not cost effective, you can tell if you've
cut them yourself. But I can run them in between other work to make
something of the downtime.
I'm still on X3, but for what I do it's fine.
Biggest problem is the variation in acrylic thickness,
even within the same sheet.
D'OH! forgot those..
yeah.. still make those. Either oval or rectangle $2.50
Can't seem to get a handle on pics though.. I'll get most
of them in there, put in one more and the rest disappear!
Rectangle corners are more rounded than in this pic, just
so you know
I keep forgetting to mention (and people ask) that the
stands do come with a protective plastic film on them.
it could be blue, could be clear, could be white plastic,
or it could be paper. You peel that off and throw it away.
Should the acrylic get scratched or hazy, PlastX or Novus
works well.. any plastic polish should work fine.
Can you do different logos on the round base of the single pen stand?
I'm afraid you're stuck with Jon Piper's logo.. Sorry. :tongue:
I'm kidding. If you have artwork, I can use that. Or I can create
something. Just let me know!
Now who would ever ask a question like that? I must say the stands look much nicer without the protective film on them :smile:
can I get 3 of the 2-tier, 3 of the 3-tier and 5 of the oval single stands?
and if possible, can i get the oval stands engraved with my artwork?
Nic
LOL Mark.. you're not alone. I work with the stuff, so I forget that
others don't. I'm constantly peeling plastic, masking etc.. so it's
just something I don't even think about. But several people have
wondered why I would sell such an ugly 'clear' stand, not knowing that
the plastic peels off. The paper is pretty obvious and people take that
off. But the clear plastic? Not so obvious. Looks much better afterwards. :tongue:
Smitty.. I have 5.75 x 2.25 x 2" for the 2-tier.
need
I want to make sure....I need {<5.75 wide...<2.25 deep --- this would be the base plate}and <2.375 high -- this would be the sides.... Is that doable
I am after one of those large stands that hold ?? was it 30 pens?? and I would like it to have engraved in it crafted by... then my details.
can you tell me in pm or here what the cost would be to ship this to England UK. i really appreciate your help and time... Jon
