merlinn
I recently purchased a used lathe (Jet Midi Model 1014) that the previous owner had started replacing the motor in.  (Couldn't beat the price.)  Everything is set to go except the wiring to the on/off switch isn't hooked up.  I've tried a few different combinations but can't seem to get the right wire on the right post.  It has two black wires, two white wires (two from the power cord, two to the motor, all with spade fittings) and two green wires with eyelet ends.  The back of the switch has two vertical and two horizontal spade fittings.  Does anyone know the proper positioning for the wires?  I don't need an electrical fire to burn my house down.
