Haynie
Is there a thread that compares PR and Alumilite?  I am looking for direct comparisons.
			That's the big thing that keeps me away from Alumilite the short 5-6 minutes work time. I tried Alumilite a few years ago and then it did not polish up as nice as PR but I think they got that fixed. Now if they could just get it stay open for a good 10 minutes. One of the cons of PR is the shrinkage. The shrinking will give you headaches if you don't plan for it. There are so many variables.
I have not started with alumilite yet and only used PR when in Japan.
Question on Alumilite: Can you vary the open time? From what I have read, 4 to 5 minutes of open time. Can Alumilite be adjusted to an open time of 10 to 20 minutes or so?
Now if they could just get it stay open for a good 10 minutes. .
So if you add less hardener and let it cure longer the PR should be easier to work with?
.... I have done a black blank where I used a piece of black PR and a piece of Alumilite Clear dyed black and .....
My basic reasoning it because I can pour PR for about 1/3 or 1/4 the price of pouring Alumilite. A five gallon bucket of PR resin and catalyst cost me less than $150. I passed out before I got the final price of 5 gallons of Alumilite.
Hmmm, I have used a lot of Alumilite black dye and have not had the tremendous troubles you have, George. ......
......Also, if you are needing black, why not use either of their resins that are already black and not have to mess with the dye? When I need pure black, I use Alumilite RC-3 Black or Alumilite Regular Black, depending on what I have on hand at the time.
Alumilite has different prices for different types on their website. Their clear is $160 for a two gallon kit from their website or simply by calling them, did you find it at a reseller for less?My basic reasoning it because I can pour PR for about 1/3 or 1/4 the price of pouring Alumilite. A five gallon bucket of PR resin and catalyst cost me less than $150. I passed out before I got the final price of 5 gallons of Alumilite.
Granted, I know nothing about this, but I'd like to try it one day, where is the best place to get both products from?
I looked a bit and found a gallon of PR and 1 ounce catalyst for $81.53 and Alumilite is $114.50 for 2 gallons. How many pens can be cast from that?
If I read correctly, Andy said he got PR for LESS than $150 for FIVE gallons not one gallon. Just giving accurate cost information!:biggrin:My basic reasoning it because I can pour PR for about 1/3 or 1/4 the price of pouring Alumilite. A five gallon bucket of PR resin and catalyst cost me less than $150. I passed out before I got the final price of 5 gallons of Alumilite.
Andy, I think you math may be off! I believe a 5 gallon kit of Alumilite costs around $550. I don't remember exactly since I never even look at the cost.
Using your numbers of $150 per gallon for PR and your claim that you can pour it for 1/3 to 1/4 the cost of Alumilite, that would put the 5 gallon Alumilite at $450 to $600. However, remember that the 5 gallon KIT of Alumilite is 5 gallons of A and 5 gallons of B, making a total of 10 gallons of mixed resin. That makes the cost for 5 gallons of mixed resin, using my $550 above, come out to $225 which is 33% higher than your PR price.
Yes, Alumilite IS more expensive, I am not denying that. But please give accurate cost information!
Hmmmmmmm back at ya! I figured I'd be called either a liar or an idiot that doesn't know how to stir a stick or spatula so I took a photo of a pen that I had a considerable amount of time invested in when I finally encountered the black goo pocket. It doesn't take much to ruin a pen, just half a pinhead size glob creates a nice little crater.
Why not....... because I also use black with clear and other color dies to create different looks when mixed with different PearlEx powders. Here is (WAS) a lower pen body where I bond a solid black finial then blend the parts together to create solid black merging into a shimmering dark silver look. I made and bonded the finial, drilled and tapped the body and was turning to the body to it's final size when I first noticed the tiny kidney shaped blob deep inside the blank. Scratch another hour and more money in the trash!
Alumilite recommends thinning the black die with part A so I just follow their recommendations.
Perhaps disguise your voice or have a friend call call and ask Carol what to do about the black TAR problem and she'll likely mention thinning with part A but when I called several months ago, having forgotten our phone conversation of 3 or 4 years ago, she didn't say a thing about mineral spirits but when asked if they were working on a solution she said "No, that's just the way it is" but she did caution me not to thin the dye with clear part A then use the die to tint white alumilite since they were incompatible...... If you call and talk with Mike or Carol, they will tell you to use either Part A or Odorless Mineral Spirits.....
CURTIS ;
My post reads less than $150 for 5 gallons of PR. At my last pricing, Alumilite was $550 for 5 gallons. Using the last quotes that I have (last week) that puts my math EXACTLY in the middle of the 1/4 to 1/3 as much for PR.
Texatdurango. Their clear is $160 for a two gallon kit from their website or simply by calling them said:No I did not find it for less. I just randomly picked one. I think it was the white or clear cast.
What is the difference between the 3 clear alumilite?
The point of my post was that if 2 gal of alumilte is 114 or even $160 it is the same cost as PR from the site I was looking at. I must be looking at the wrong site. I may start with alumilte (Curtis was convincing) but then I need a pressure pot right?
Mark,Hey, lets all go down to the Dirty Inkwell. Drinks are on me and we can all shake on it.
So, summers here are 100+ degrees and I am not going to be allowed to cast in the house. So, which will give me the longest working time?
SO you DO need a pressure pot for Alumilite.
PR it is.
PR it is.
I used to make "worthless wood" blanks where you want the resin forced as far into the wood grain as possible so pressure is a must.
Also I use clear and white with colored dyes and PearlEx pigments, these blanks too need pressure to get rid of the bubbles.
When mixing small 30 gram batches to test new colors I do not put them in a pressure pot and it shows....every one of them have tiny air bubbles throughout the blanks so I would say that I wouldn't use alumilite for pen blank making without a pressure pot in the above situations.
The above situations are based on my personal experiences only and I am simply sharing my personal opinion, not necessarily facts.
