GrantH
If so, do you mind sharing some tips on what to use for mounting, how you turn them, what goes over well??
Pics are always good!
I have used a threaded insert that will accept a 3/8-16 bolt like on taps for a couple of handles made in the past. Available even at your local big box hardware store.
galvanic corrosion should not occur between brass and stainless in all but very harsh environments.I have used a threaded insert that will accept a 3/8-16 bolt like on taps for a couple of handles made in the past. Available even at your local big box hardware store.
Would using brass with stainless steel cause bi metal corrosion?![]()
