Scallops how to.
AceMrFixIt
Jacksonville, FL
When trying to scallop both ends of both barrels on a pen, do you cut the blank to length prior to adding the scallop peices? Thank you in advance.
If it is a one piece blank yes. If it is a two piece, it depends if you need the grain to match from body to cap. If you do, then you need to cut to length first, or you will cutting off the grains that need to match between the cap and body.
Its a 2 piece pen. Not concerned with grain at this time. Just want to scallop both ends of both barrels.
