Suggestions on lathe
sjhuse
Rio Rancho, New Mexico
I'm just starting out turning so this is all very new to me - (I turned my first pen this weekend with a friend). My Father n law gave me an old craftsman lathe Model # 103.23070 that's missing the motor. (and possibly other stuff not sure till I can really look at it). I was wondering what motor I should put on it and where I would get other tools for it (like centers/chucks or what ever I need for turning)
I've included a picture of the lathe - any suggestions?
Sherry
The motor will cost more than the old lathe is worth. Been there, done that. The cost of the lathe is about 40% of the total cost of getting set-up. Check out the local wood turning club talk to the club members. Most will be more than happy to let you test drive their lathes.
You don't mention where you are in NM, Woodworkers Supply in ABQ are great people to deal with. Very friendly and they know their stuff.
I bought a Delta 46-450 Midi lathe and love it. Welcome to the vortex.
I'm located in Rio Rancho next to Albuquerque. I was thinking a new motor might be $100-150 and new lathes cost several hundred $400-500 for a decent one maybe. I don't know. I definatly don't have the moeny to buy a new lathe at this point but don't want to waste money restoring this one if it really isn't worth it. Thanks for your suggestion - I'll check out woodworkers supply.
Sherry
Look on Craig's List. You will need at least a 1/2 hp about 1725 rpm. Just about any motor with a mount will work, even an old washing machine motor. Old evaporative cooler motors also will work. I have found them as low as $30. It may take a little while, but keep an eye out on Craigs and junk shops. Used motors are good enough.
As to the lathe, I would keep it, classic old iron. With proper care and maintenance it will last forever. When you make your first million, and buy a new lathe it can be used for a buffing station. Or give it to me, I love that old iron.
If you were closer to Ruidoso, I could bring one up next month when the kids go skiing. But that drive would cost more than the motor cost.
I think that the less expensive route of rebuilding this lathe and getting it working is worth a small investment. It may not be the latest and greatest, but in it's time it was. It will work until you get some time and practice into the hobby.
Since you have already said that your budget is tight go the frugal and industrious route. Make this machine run as well as can be done for as long as you can.
Good luck!!
P.S. You can continue to use my Craftsman and my mentors loaner Jet mini at my house.
Thank you Donovan I really appreciate you letting me use your shop while I get one set up and all the help in teaching me how to turn. I haven't called pawn shops yet but I will, thanks for the idea.
