Scooley01
Ok, so I'm having issues with a couple of my tools...I'm sure it's probably operator error since I'm fairly new to this, but asking questions is how you learn
My band saw: Brand new Skil from the hardware store. When I cut, I set up the fence to the right diameter, and use the sled to push the blank through. However, as I cut, the blade pulls to the right (Away from the fence, towards the slide and my hand). It pulls farther faster if I try to push the blank through too quickly. It's actually pulled far enough to the right that it's nicked the table the blade goes through! Also I notice that on the last few blanks I've done, the blade binds very quickly with any pressure. I've cut less than 20 cuts on this saw! This is an annoyance and keeps me from cutting straight lines.
And onto the big problem: My lathe. I think that the HS and TS might be out of alignment...but I don't know how to properly diagnose or fix this problem. I've had a couple problems drilling (See Penturning forum for my 10mm bit that snapped in half) If I slide the tailstock away and spin the HS by hand, I can see visible wobble in the mandrel...I would have originally thought maybe the mandrel was just bent, but I take the mandrel assembly out of the lathe to use the pen jaw and drill chuck, so I'm not sure what's causing these issues.
Hopefully some of you smarter guys can help me figure this out!
