Atrax--Midnight Flames
See more from ed4copies
ed4copies
Local Chapter Manager
Racine, WI, USA.
Well, I've turned a couple pens again, with my new vision!!
This one is a newly available component set and some material I happened to have in the basement:biggrin::biggrin:
Hope you like---I do.
Comments and critiques welcome:rolleyes::rolleyes:
Tim,
Uses the same size bushings as the Jr. Gent series---but it is a "stripped down" version. Very simple and affordable!!
Just took a look at 'em....admittedly for the first time. And I like the pricing you have assigned them.
Question: Is the clip as heavy duty as it looks in all the photo's I've looked at? And what are the tube sizes(seeing if I can use these pieces to turn closed-end, and save some cha-ching)?
Great looking turned pen!
Scott (less expensive = big bonus) B
Scott - I've not checked the lengths - but the tubes are the same diameter as a Jr Gent. If you go look for my SOYP, I made 2 closed end pens (1JR, 1 Atrax) last weekend using the same mandrel. I havn't done cap closed yet, but you should be good there too.
Looks like you have been busy, Gerhard!!!
Your collection of Atrax demonstrates another thing I like about the "family"---the clip ends look extremely similar, so if you have a ballpoint and RB/FTN in your pocket, they match!!!
This is not true of many "families" of pen.
Nicely done sets!! Thanks for showing!!!
looking good Ed!
Did you reverse paint?
Phil
No, I rarely paint Phil!!
If SOMEONE is going to screw them up, I HOPE it will be me, so I TRY most of my materials without paint.
This one turned out really well, but the amount that remains on the pen is fairly thick.
Hope this helps others!!:biggrin::biggrin:
