yorkie
Has anyone ever made a jig for cutting grooves in a blank lengthwise?
I just used my rip fence on my Table saw... but I was using a square blank.
On a serious note you could still use the table saw hypothetically (I've never tried this), but you would have to make the blank an octogon (for eight pin strips) first. Then it would just be a matter of rotating the blank and cutting your groove.
I could set the blade at a 45 or 60 degree angle to cut off the edges and still keep the blank square, and then I would have eight flat surfaces to work with. Hmmm.
If this is more than a one-time thing, you should look into an indexing wheel and a rotary tool attachment...
