JD Combs Sr
Timothy Wise(AKA "wiset1") posted a full sized Majestic dressed in Cocobolo and Brazilian Cherry the other day(01/01/12). The wood was in the form of knife scales giving the pen the look of a very nice pocket knife. I asked Tim if I could copy it and this is the result. Thank you Tim for the inspiration. The only kit I had to try it out on was a Black Titanium/Chrome Sierra. I think it came out good but I think it would have looked better if the Sierra had had some gold on it. I am thinking I will order me a Gold/Chrome kit and move the barrel to it and see how it looks.
As shown here I did use the method that I mentioned in his thread (the two piece center). That's a scrap piece of 1/8" UHMW in the center cut to the same width as the tube diameter. It drill real easy.
Edit: Forgot to detail the material
Black Walnut Outer scale, 1/64" aluminum sheeting separator, BLM Burl, and the Center rib is 1/2"x1/8" aluminum. Finish is 10 coats of CA polished to 6000mm(purple), I wanted it shiny but not glassy.
