galoot_loves_tools
I have been using the Mandrel Saver from PSI and like many have found it necessary to crank on the tail stock pressure to keep it from slipping. However, I recently tried using small neoprene O-rings between the bushings and spacers, basically wherever metal-to-metal could slip and that did the trick. Much less pressure needed to successfully turn the blank.
