Wholesale tool main store and warehouse has the ER32 collets too And start under $20.00 bucks each.
Wholesale Tool Company
12155 Stephens Dr.
P.O. Box 68
Warren, MI 48090-0068
Closer to you, no connection only a long time satisfied customer
wttool.com
:clown:
$20 for each collet gets expensive very quickly.
Not when other companies are charging, $35.00 and up for the same import collets. This way you can start out with the chuck for the wood lathe and get the collet you need, as you need them.
If you can get a set that covers the sizes you need and want to pay the amount. then that is an option too.
The collet chucks for most metal lathers have slightly different set up than the common import wood lathes no matter what name is on them.
:clown:
