As I am cleaning up my shop I keep coming across more and more stuff that just takes up space, it needs to go.
STABILIZED WOOD BLOCKS
Here is a package of stabilized wood blocks. Most are 1.5" square, some have been cut into halves, all are of a length suitable to make pens out of. Some have the species labeled, each box has some really pretty buckeye burl (this is the last of 3 boxes I had). Some randomly picked blocks are shown in the photo
A stabilized pen blank is typically around 2 oz, i.e. 8 to the pound. I filled 3 medium USPS priority boxes, each is about 15 lb (there is 1 box left now). You can calculate how much 15 lb of stabilized blanks cost you these days (appr. 120 blanks). You'd be looking at $600-1000! I'm asking $239 for each box, plus $11 USPS priority shipping within the US. Shipping to Canada runs $27. SOLD
ANTLER:
Again I have WAYYYY too much. Quite a bit of it I bought probably 15 years ago from one of our members who ran a deer farm. It's been stored indoors. I found an invoice attached to one of the old boxes - I paid over $10/lb at that time. I'm asking $5/lb - if you compare that with antler prices at our reg. suppliers you'll find it's a very good deal.
Box 1 is a mix of elk, mule deer and reindeer. Weight is nearly 11 lb. I am asking $50 plus priority postage from zip 12590, it does not fit in flatrate box SOLD
Box2 is random antler, some whole, some bought as blanks, a few pieces are drilled for cigar and 7mm. It also has a piece of moose. What's in the picture is not all that's in the box, I fit the moose and large pieces then added as much material as I could fit. The box weighs over 17 lb. I am asking $85 plus $15 priority shipping (large flatrate box, within the US) SOLD
Box 3 is large antler. Some are very solid, others have porous core and need to be filled, if making pens. Some are fat enough to make small vases out of. A piece of a moose antler is in there also. Weight is a little over 19 lb. Asking only $75 plus priority postage from zip 12590 (does not fit flatrate box)
STILL AVAILABLE
PEN KITS
(K1) CSU 7mm black chrome twist pen kits (050-2404), $25 for 10 (available 3 packages) (uses std 7mm bushings) SOLD
(K2) CSU 7mm black chrome twist pencil kits (050-2405), $30 for 10 (available 2 packages) (uses std 7mm bushings) SOLD
(K3) CSU Presidential pen kit (050-4430). 5 for $20 (bushings are available from CSU if you need them) This is a 7mm kit with a nice spring-loaded clip EARMARKED
(K4) CSU KC Twist satin gold pen kits (050-4451), $20 for 10 (The KC Twist pen is a 7mm pen with longer front tube and no CB) (uses std 7mm bushings) SOLD
(K5) Easy grip kits: 13 10k, 6 satin nickel, 1 satin gold, 1 spare tube, bushings, 20 grips (7 black, 1 red, 2 blue, 1 green, 4 gray, 5 clear) $50 for the lot. SOLD
(K6) 4 CSU Americana 10k pencil kits with the Artisan CB. These use the Schmidt twist mechanism. $10 takes them SOLD
Shipping on any of these is additional, USPS priority rates. Of course I'll combine shipping where possible.
ANTLER:
STILL AVAILABLEPEN KITS
